ABS, ignition switch?
Very common issue. There just needs to be the smallest amount of play in the bearing to cause the gap by the sensor to open up.
Good luck
Good luck
I was wondering, does anyone know if there is a way to measure the vss position? The one that's bad has a few shims on it.
You mean WSS (wheel speed sensor)..? You have to measure the output as you spin the wheel. The output needs to be >250mV-AC. If it is too low, that means the gap is too large and needs to be adjusted in.
Brian5792
10-24-2018 11:34 AM
