ABS light/speedometer/shifting problem
Old Jun 1, 2018 | 08:15 AM
mattjphoto's Avatar
mattjphoto is on a distinguished road
Default ABS light/speedometer/shifting problem
My ABS light came on but everything seemed to drive fine. Then a brake light flickered for a second and I lost my speedometer and Blazer wouldn't shift into higher gears. ABS light turns off after Blazer has been restarted. Would this be a VSS issue as I read it controls ABS and speedometer? If so is this the correct on for a 2002 LS 4x4 4.3L?
Expensive version? https://shop.advanceautoparts.com/p/...310/18481043-P
Cheaper version?
https://www.amazon.com/ACDelco-19302667-Original-Equipment-Vehicle/dp/B00S0FOD14/ref=sr_1_10?s=automotive&ie=UTF8&qid=1527859315&sr=1-10&keywords=vehicle+speed+sensor https://www.amazon.com/ACDelco-19302667-Original-Equipment-Vehicle/dp/B00S0FOD14/ref=sr_1_10?s=automotive&ie=UTF8&qid=1527859315&sr=1-10&keywords=vehicle+speed+sensor
Old Jun 1, 2018 | 01:20 PM
Mike.308's Avatar
Yes, seems the system does not have a VSS feedback signal, so limp mode is activated with ABS fault control. AC Delco provides a quality parts, I'd go for it. But prior ordering make sure it's not the wiring
Old Jun 12, 2018 | 04:08 PM
mattjphoto's Avatar
Old Jun 12, 2018 | 05:49 PM
Mike.308's Avatar
At least, does it work for You?
Old Jun 13, 2018 | 09:27 AM
mattjphoto's Avatar
I'm going to order it today. I was praying if I cleaned the sensor off and checked the wires it would magically work. On the way into work this morning the Blazer acted up . Should I order the AC Delco or get a BWD from Advanced today? I've always put AC part pack in but I can get the BWD today for the same price.
Blazer4wd
Oct 10, 2018 04:26 PM
cas
Dec 23, 2013 07:54 PM
elgemcdlf
Sep 3, 2013 06:13 PM
lionel2
Mar 21, 2011 01:55 PM
max1995
Dec 6, 2010 08:24 PM
