AC Compressor
Old Sep 21, 2014 | 03:48 PM
john lovsey's Avatar
john lovsey is on a distinguished road
Default AC Compressor
My Bering on my AC compressor is bad can I just replace the compressor with a new one or do you have to replace other items as well. Then recharge the system. I might add my air works really well nice and cold just that my tensioner went bad and took out the AC pulley bearing nothing else. I replaced the tensioner serpentine belt and it still works really well just noisy bearing like.
Last edited by john lovsey; Sep 21, 2014 at 03:59 PM. Reason: Add more information.
Old Sep 21, 2014 | 04:25 PM
The repair depends on which bearing is bad. If it is only the clutch bearing as it sounds like it may be, you can get away with just replacing the clutch with a new one and you'll be good to go.
If it is one of the bearings inside the compressor, you may be in for some hefty repairs as when they go, the internals of the compressor typically touch and throw little bits of metal throughout the system.
Old Sep 21, 2014 | 08:24 PM
No it is the pulley bearing and the price of a new pulley with Bering is about the same as a complete compressor with pulley and clutch.
Old Sep 21, 2014 | 08:30 PM
chris015's Avatar
replace whats bad,rent a vacuum pump,vacuum the system,and add 2 small cans of freon. and roll.
as long as the everything works right...
cant do this? pay someone else with the right stuff to do it.
Old Sep 21, 2014 | 08:51 PM
Chris 015 So should I use the vacuum pump on the system before mounting the new compressor or after.
Old Sep 21, 2014 | 08:57 PM
chris015's Avatar
after...
once you have it all hooked up. add the pump,supply vaccum. should show -25,30 on the gauge after 20 min of running it.. close the valve. watch the gauge....does it leak down? you have a leak...
more or less your doing this to save 30.00 in freon.
Old Sep 21, 2014 | 09:43 PM
If the pulley is all that is bad, I would not recommend opening up the system. Especially so if you do not have the proper means to recover the refrigerant that is in there already.
Old Oct 13, 2014 | 04:37 PM
Smile The A C Compressor
Upon inspection along with the compressor pulley my tensioner and idler pulley was bad so even though my serpentine belt was great looking I replaced it, the tensioner the idler pulley the compressor and had it evacuated and recharged. Now those irritating noises from the belt area are gone. Now I am keeping the serpentine belt for a spare [emergency] I am also going to replace the bearing in the idler pulley to have a spare one of them as well. So that resolves all my issues at once glad I took the belt off and checked all the pulleys it probably saved me from a break down further down the line.
gmcjimmy_94
Dec 30, 2010 12:37 AM
bcw757
Jul 3, 2006 08:44 PM
SniperX13
Jun 4, 2006 02:59 PM
NJEMT
Jun 1, 2006 01:40 AM
tammikm
Oct 28, 2005 12:15 AM
