AC leak...photo attached
Old May 5, 2008 | 12:23 PM
JediKnight2's Avatar
JediKnight2 is an unknown quantity at this point
Default AC leak...photo attached
I just had my accumulator, evaporator and orifice tube replaced because the evaporator went...A week or two ago some of the green dye was in the same location of the photo below...I wiped it up and cleaned it all up to see if it was a leak...today I see this..
If you look below the compressor...lots of green dye there...is this a sign of a bad compressor....it does make a racket when I turn on the AC...I can post a vid up with the noise if need be.
Old May 5, 2008 | 12:36 PM
Default RE: AC leak...photo attached
Yep, seal on the compressor crapped out on you. Is the system still operational? I guess it is possible that the system was overcharged.
Old May 5, 2008 | 12:39 PM
It is still blowing cold air...so that means a new compressor...cruddo...
Old May 5, 2008 | 01:53 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
If you are working on this yourself try ackits.com for parts. That's where I gpt parts from when I refurbished two systems recently.
Old May 5, 2008 | 02:55 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Yah I have the same compressor and leak if it works it wont for long.
Old May 25, 2008 | 06:28 PM
muleman's Avatar
muleman is an unknown quantity at this point
so is the compressor junk and needs replaced or can you put new seals in it??????
Old Jul 4, 2008 | 03:21 PM
Well...it finally went out the other day. I was just trying to milk it until it failed...NOW my question is this...a few months ago I had the accumulator and orifice tube replaced....after that is when the compressor seal went....is it necessary to REPLACE those two things AGAIN...??
Old Jul 4, 2008 | 05:32 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
Depending where you got them from, they should have came with a warranty. Take them back and have them exchange them out. Make sure you let them know that you are buying a compressor and they will help you out all they can.
camohunter
Feb 11, 2015 08:25 PM
kickme005
Sep 6, 2010 06:03 PM
kyle123
Apr 4, 2010 02:27 PM
swoop
Feb 2, 2010 11:04 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
