adjustable orrifice tube?
Old Jun 16, 2012 | 03:28 PM
50lb_cat's Avatar
Default adjustable orrifice tube?
The compressor took a crap in my 99 jimmy so I had the system evacuated and flushed. I bought a new delphi compressor and accumulator. I'm wondering if the auto adjusting tube is worth the extra 20 bucks? Has anyone ever used them? Thanks for any input!
Old Jun 16, 2012 | 07:03 PM
Replacing the FOT, (Fixed Orifice Tube) with a VOV, (Variable Orifice Valve) makes a noticeable difference in AC performance especially in high ambient temps and or idling in traffic. Absolutely worth the money!
The FOT uses a stationary orifice, (the diameter is "fixed"). High ambient and underhood temperatures, along with poor air flow through the condenser & radiator, causes head pressure to rise. This causes refrigerant flow through the evaporator to increase and flood the evaporator, which causes register outlet temp to increase. The VOV automatically adjusts when the head pressure increases, reducing the refrigerant flow through the evaporator.
Old Jun 16, 2012 | 11:07 PM
50lb_cat's Avatar
Thanks captain! I wasn't sure, I don't work on ac systems very often. The guy at the parts counter just said buy it because its better with no further explanation.
Old Jun 17, 2012 | 12:06 AM
richphotos's Avatar
This is interesting, is this something that could be put on an existing system? Example, Could this be something I could put on to my 93?
Old Jun 17, 2012 | 12:48 PM
Yes, it will fit any GM vehicle equipped with a CCOT, (Clutch Cycling Orifice Tube) system. The VOV replaces the FOT. 10 minute job with no special tools, but it does require draining, (recovering) evacuating & recharging the system.
Buy Tough One or Factory Air Orifice Tube T38902 at Advance Auto Parts_____
TennesseeBoy
Feb 3, 2014 06:41 PM
whitezr2
May 22, 2010 11:28 PM
SCHLAKER-PTZR2
Lowering Tech
Mar 5, 2010 08:16 AM
v8vairman
Apr 12, 2006 01:43 PM
02 Vortech
Engine & Internal
Jul 8, 2005 08:47 AM
