Air bag sensor replacement
Old Jun 28, 2025 | 05:22 PM
nomoresubies's Avatar
nomoresubies is on a distinguished road
Default Air bag sensor replacement
So my airbag sensor light comes and goes. I checked the resistance as indicted here and it all seemed good, cleaned the connections but to no avail.
I got some replacements from the junk yard but it turned out the connections were different so unusable.
So were the OHM values for specific years also and incorrect for my year?
Are the sensors sold aftermarket or just salvage yards?
Thanks again
2001 ZR2
Old Jun 28, 2025 | 06:34 PM
I think for my 99, the max senor resistance is 1,000 ohms, bur I can check my service manual later if that would help.
Old Jun 28, 2025 | 06:36 PM
Thanks for the reply. I would appreciate the resistance values again and the terminals to check also as I don't think I kept my information or at least I can;t find it...
Old Jun 28, 2025 | 11:04 PM
I'll try to get those to you later tonight or tomorrow.
Something I did was instead of reinstalling the sensor with a rivet, I installed a riv-nut.
Old Jun 29, 2025 | 01:16 AM
I've attached excerpts from my 99 Service Manual. I think these should help. Let me know if they do or not.
The threshold value for the resistance appears to be 950 ohms and 1050 ohms depending on the particular circuit. You might have to check if the circuit has a good ground.
Good Luck and let us know if you get it fixed.
File Type: pdf
File Type: pdf
Old Sep 22, 2025 | 05:38 PM
After all the head beating it seems to be only a bad connection at the drivers side sensor.UGH!
Old Sep 23, 2025 | 03:46 PM
Whoops! Glad it was an easy fix.
christine_208
Jul 8, 2018 12:08 PM
Camfrank227
Oct 17, 2017 08:40 PM
jackpinesaavage
Apr 13, 2014 10:27 AM
cucv30
Jun 3, 2012 12:40 AM
Larry's98
May 26, 2011 12:05 PM
