AMP wire install sub speaker
Old Sep 10, 2015 | 11:40 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
Default AMP wire install sub speaker
alright guys I installed a amp and sub in my blazer and thought I would share it with ya.
its for the 2nd gens but could also work for the 1st gens as well.
Old Sep 10, 2015 | 11:52 PM
bam_9_9_9's Avatar
also I have upgraded to a ad244 alternator which is a simple install in any blazer jimmy and bravada, Sonoma, s10.
I will put up a vid soon... after this.
Old Sep 11, 2015 | 09:24 AM
Tajohns34's Avatar
8 Gauge is pretty good for 1 amp usually. I have 4 gauge run to mine but it is a 5 channel. I also used a rubber grommet to run it through the firewall. But your method is fine also.
Old Sep 11, 2015 | 03:04 PM
Thogert's Avatar
I've got 4ga on both of my amps, one 1KW mono and one 600W 4ch. Overkill, but I don't want to worry about it. Also, 4ga and 0ga wire just looks killer.
Old Apr 26, 2021 | 12:01 AM
LeFlamaBlanca's Avatar
LeFlamaBlanca is on a distinguished road
Default Bro! Thank you!
I sat there scratching my head staring at that firewall that practically every square inch of is covered by SOMETHING! going, Where the hell am I gonna go to get this wire in the cab! And thought well let me do a quick search and found your post! it worked like a charm! That was a life saver mainly because I'm ****ing lazy and didn't wanna have to drill a hole AND because I couldn't spot one place where I could actually drill without removing the hvac housing or anything else. Again, Thank you! Gotta run the ground tomorrow and finish hooking everything up but your post was a real life saver!
Amp Subwoofer install Blazer Jimmy Bravada S10 Sonoma - YouTube
Old Jan 7, 2022 | 04:20 PM
NickChase's Avatar
NickChase is on a distinguished road
Thanks for the helpful video. By the way, you have a good sound scheme. I want to share with you the experience of installing speakers on a Jeep Wrangler subwoofer. Installed Polk Audio DB522 DB + Series 5.25 '' Jeep coaxial speakers, ordered jk speaker upgrade here https://boostyourengine.com/jeep-jk-speaker-upgrade/. Sound bomb 10 out of 10, A little overdone with the volume in the yard and the neighbors called the police. I recommend it.
Steve-o
Oct 18, 2013 07:54 PM
juanfpina
Feb 9, 2012 10:59 AM
chevycrazy2011
Feb 22, 2011 12:52 PM
tjbmxrider
Apr 12, 2008 07:45 PM
87s10blazer
Jan 20, 2006 09:16 AM
