Any ideas??
I've had this wet area on the passenger side for over a year now. It doesn't mark up the driveway, but it's a mystery to me so I wanted to post up some pics (links) and get some feedback. It is the area where the CV connects to, well, whatever it connects to--the hip bone?
https://i.imgur.com/vGemIIC.jpg
https://i.imgur.com/bLCMtZ7.jpg
https://i.imgur.com/5v9Rx6H.jpg
BTW...it's an `01 Bravada
Appears to be the seal for the half shaft. The half shaft will need to be removed to replace the seal. Make sure the front differential fluid level is correct by removing the upper, (fill) plug. Should be even with the bottom of the hole.
Very important that the differential has sufficient fluid, (80W90). If it runs out, and the differential seizes up, your DIY job went from $10 to a few hundred! Fair amount of work to remove & install the half shaft, (1.5 hours) but once it's out, replacing the seal is a 5 minute job. Seems like I saw thread for replacing the half shaft here on the forum.
gizwilly
09-05-2007 11:08 AM
The Franchise
03-10-2007 10:54 PM
hicksjw
01-10-2007 04:32 PM
