AWD hub questions
Old Feb 4, 2011 | 05:36 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default AWD hub questions
I have what I beleive to be a bad hub on the passenger side. It sounds kinda like a loud snow tire on one wheel only and get louder as the speed increases but not rpm dependent. It also gets louder when more weight is shifted to that wheel also. Is there any different steps or things to watch out for when doing it on a Bravada since its AWD vs the hubs on 4wd. Also I've seen on some sites that you should change the axle nut when you have to take it off, but the diy thread I saw on here doesnt mention replacing it any input on this?
Old Feb 4, 2011 | 06:21 PM
The hub is the same 4wd to Awd. I have never replaced the nut. It should still work just as well.
Old Feb 4, 2011 | 07:25 PM
portcqb's Avatar
Ok it shouldnt be that bad then, I just ordered the 36mm deep socket and the timken hub assembly
babeba67
Mar 21, 2015 08:31 PM
rockgolfer
Aug 19, 2013 09:25 PM
dougg01
Mar 17, 2010 10:49 AM
VAblazer
Jun 12, 2008 08:18 PM
bigrackhunter50
Apr 11, 2007 01:08 AM
