Backup camera installation help
Old Jun 25, 2022 | 06:25 PM
PhantomDiesel's Avatar
PhantomDiesel is on a distinguished road
Default Backup camera installation help
Hey y’all I just purchased a double din radio with a backup camera that mounts to the front of the license plate and T-taps to tap into the reverse light wiring and I’m not sure how to do a clean install with out exposing the wires
I’m trying get from the top of the license plate to the right tail lamp wires
Old Jun 25, 2022 | 06:37 PM
GeorgeLG's Avatar
Are you looking for the wire route or the way to mechanically attach to the existing wiring?
George
Old Jun 25, 2022 | 09:36 PM
I’m looking for a proper wire route and I can’t find one
Old Jun 25, 2022 | 10:14 PM
If you have a lift gate, there will be a rubber bellows that covers the wires that go to the remote locks. It is located near the hinges.
If you have a tailgate, you might have something similar.
Old Jun 25, 2022 | 10:31 PM
GeorgeLG's Avatar
I’ll let Christine and others who have been back there help you. I have only connected to the trailer wiring.
George
Old Jun 25, 2022 | 11:56 PM
It’s a lift gate that lifts up. So I have to run the wires up the right side of the door seal and into the bellow then back down behind the trunk bezel and into the reverse light wires?
Old Jun 26, 2022 | 12:11 AM
Dang, I'm sorry. I got it in my head that you needed to get to the lift gate to mount the camera. You do not need to get into the lift gate itself.
The backup lights look to be accessible from the access panel for the jack. I just now looked and saw wires that look to go to the driverside rear lights. You will likely have to remove the body of the light to confirm which wire goes where.
Old Jun 26, 2022 | 10:20 AM
Hess13x's Avatar
All of the rear light wiring is behind the bumper. Hope this helps
Old Jun 26, 2022 | 03:13 PM
It does thank you
RaDiCal_Beaver
Oct 21, 2015 09:27 AM
Ryanmatt135
Sep 29, 2010 07:39 PM
PyroCustoms
May 11, 2010 05:41 PM
Canadian88
Jun 25, 2006 04:33 PM
stlguy85
Feb 3, 2006 03:19 AM
