Battery Drawdown ?
Old Nov 7, 2021 | 02:10 PM
lathechips's Avatar
lathechips is on a distinguished road
Default Battery Drawdown ?
2004 S10 Blazer battery draws down, wont start after about 5min. with the rear hatch open/dome light on. Battery test shows good.
Old Nov 7, 2021 | 03:48 PM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
That would take a major short to kill a good battery that quick. One that could cause a fire. How are you testing the battery? When you disconnect/connect the battery, is there a large arc?
Old Nov 7, 2021 | 05:47 PM
GeorgeLG's Avatar
Agree with Walleye Hunter.
A proper battery test:
Charge fully, knock off the surface charge and hold 12.65V min
Electrolyte measures good and balanced if access to cells
Load test at 1/2 CCA for 15 sec (100's of amps), voltage never goes below min (9.7V at 80F)
Battery bounces back to above 75% charge (12.37V)
If you have an amp clamp meter measure one of the battery cables during the draw down.
George
Old Nov 7, 2021 | 08:03 PM
lathechips's Avatar
I had it tested at the same place I bought it from, the local battery, tire, brake, ect. store.
Old Nov 7, 2021 | 09:26 PM
GeorgeLG's Avatar
What is the voltage at the battery posts after its charged up and while attempting to crank?
George
blazz
Dec 14, 2017 11:48 AM
ryanoz1987
Feb 25, 2017 08:50 AM
donald_archer
Feb 17, 2014 03:15 PM
19echo95
Oct 11, 2011 09:15 PM
SDimeBlazerlady
Dec 30, 2006 03:43 AM
