Wheel hub bearing
Old Jul 25, 2007 | 06:04 PM
Maldo15d's Avatar
Maldo15d is an unknown quantity at this point
Default Wheel hub bearing
i've been ragging on my blzr for a while and i need to replace the wheel hub bearing i need some tips and stuff, would it be better to replace the two front one's or cheaper to just due the damaged one?
Old Jul 25, 2007 | 08:35 PM
Hanr3's Avatar
Default RE: Wheel hub bearing
Tips go here.
https://blazerforum.com/m_56421/tm.htm
One hub assemble is $180 bucks. If you got $400 bucks laying around to swap parts go for it. Otherwise most replace them one at a time.
Old Jul 25, 2007 | 10:37 PM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Just replace the bad one. That's what I did.
Old Jul 25, 2007 | 10:42 PM
bigbill23's Avatar
bigbill23 is an unknown quantity at this point
just replace the bad one however, remember that noise can and will travel, which could lead you to believe that the good side is actually bad! If u can understand that!! Basically, noise can and will transfer from one side to the other side of your truck very easily, so be prepared to put the hub on one side and go for a test drive afterwards and still hear the noise, problably replaced the wrong one! Bottom of the line, be ready to remove and replace the same hub bearing twice!!
Old Jul 25, 2007 | 10:44 PM
If you can get the truck in the air, it's very easy to tell which side needs replaced by rotating the tire with your hand. Don't go by the sound. The side that needs replaced will feel rough as you spin the tire. Just have some common sense and you shouldn't be replacing anything twice.
Old Jul 26, 2007 | 06:30 AM
bigbill23's Avatar
most bearings need to have a load on it to tell if its bad or not, unless its just loose. But you cant always tell by spinning the tire in air which one it is!
Old Jul 26, 2007 | 06:59 PM
Maldo15d's Avatar
yeah, i know what you mean, and the noise goes away and the weight shifts on a turn and i shake the passenger side front tire and i can feel the difference ... Its about to go out , bad , i stopped driving it cause its scary.
samurai_24
Oct 2, 2009 12:39 PM
sfcustoms2006
Sep 26, 2009 08:23 PM
bigrackhunter50
Apr 11, 2007 01:08 AM
Marcin
Nov 9, 2006 11:31 AM
Chavez96
Sep 20, 2006 04:04 PM
