Bi-Directional Scan Tool.....Questions
#31
I was going through the various pages on the ilink400; came across one for setting the idle....hhmmmm...wonder if that works??....it was showing a setting of 650 rpm and the tach was showing something near that. I pressed the down arrow and it changed to 625 and the engine idle dropped a second later...wow!!.....it works! Changed the idle RPMs several times and each time the engine responded.....so once again that feature does work.
Anyways hopefully doing the CKP Relearn will take care of the mis fires I get after driving for awhile. I had replaced the timing cover six months ago, was expecting the Service Engine Soon lite to come on after getting everything back together, but never came on. But after driving on the highway for a while and then to surface streets will get rough idle and sure feels like misfires although has never set the SES on.
Will find out the next time I head-out on the highway.
Oh and very interesting to read that the relearn is actually done on the decel....sure makes sense. And I did let the engine decel back to idle after the fuel cutoff occurred before I shut the engine off.
Thanks again.
Thanks again.
#32
Captain Hook used to state "The truck will run, but it will not run optimally without the relearn".
That all being said, I agree with you Les. I kinda don't think the learn will end the issue Lanny is describing. I could be wrong.
The description of coming off the highway to town and idle problems sounds more related to an idle air control issue. Note I am not saying there is necessarily a problem with the IAC valve itself. When driving, on decel (there's that word again ), like coming down a hill, the VCM/ECM is setting up the IAC for the counts it should be at when it's time to take off from a stop. Of course the VCM is getting its data from other sensors. I picture it as, for example, if the ECT sensor is off by a bit, then based off the tune map in the VCM that can throw off where the IAC should be at at idle. That's just an example I made up. Scanner Danner has a great video that is a much better explanation. I think it's one of his free ones and I'll try to find it.
#34
Christine: your question, was replacing the timing cover hard to do?.....yes it is on a 4wd, probably much easier on a 2wd. Hints......have someone else do it.......
The main issue is the large gap in the timing cover for the oil pan gasket....this has to be filled with RTV or it will just leak. To replace the timing cover, I say the oil pan has to come off so as to clean out all the old RTV. To get the oil pan off the front diff has to come out. Which requires the front axles to be removed. Which requires separating the upper ball joints at least, tie rod ends, or guess you could just remove the front spindles. Oh and of course the coolant has to be drained, radiator removed, fan removed, coolant pump removed, starter removed, front shocks removed. Then the oil pan can be dropped, then the front cover.
Now back to CKP relearn. As I stated way up at the beginning, I was expecting to get a SES lite after replacing the timing cover but did not. But since the misfires I felt when stopped, trans in D, foot on brake only began after the timing cover replacement, I just thought that somehow the CKP sensor valves were close but not close enough when the engine was ran for a length of time....so that is why I thought I should do the CKP relearn as it was likely the cause of the misfires. Perhaps this is wrong.
I drove today for the first time since doing the relearn, but not for any great amount of time, had no misfires, no SES lite either.
Guess time will tell if I actually have another issue.
Keep the discussion going.....always willing to learn more.
#35
Was curious if you still have no misfires and/or no rough idle coming off the highway since you completed the CKP relearn? Just curious for future reference.
#36
So far all is good, but have not had the Blazer on the highway for more than about five minutes since doing the CKP relearn.
I might be able to do a test tomorrow (3/14) though. If I do, I will up-date this posting.
UPDATE:
I was able to get on the highway for a while yesterday, noticed two things: 1. Engine ran better in that it seemed that it was easier to maintain 75mph than before. In fact, I had to lift my right foot a bit every so often as I was going faster. Normally I would stay about 70-73 as above seemed to be pushing the engine hard.
2. Coming off the highway and into stop-n-go traffic I still had a rough idle/misfire, but nowhere near as prevalent as before the CKP relearn. I did install poly engine mounts a couple of years back, so I do feel more vibrations.
Still no SES lite. Have not checked for any pending codes and I will put the ODB 2 scanner back in so I can monitor misfire PIDS on my phone for the next highway trip.
Later
UPDATE:
Later
bigkeith11
07-13-2012 10:21 PM
