Blazer Dieing
Old Dec 6, 2008 | 09:28 AM
WolfPack's Avatar
Default RE: Blazer Dieing
ORIGINAL: PABlazer
this will b my third 1 from auto zone in 2 months
Buy an OEM rebuild..same with CV axles...aftermarket replacements just dont hold up.
Old Dec 6, 2008 | 11:04 PM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
the alts r rebuild... thats what i asked today when i was there
Old Dec 7, 2008 | 11:38 AM
WolfPack's Avatar
Interesting..hrm..
Old Dec 7, 2008 | 04:26 PM
PABlazer's Avatar
sorry bout that...
my idle is right around 500 RPM... as soon as i put it in gear the voltage just drops and doesn't go back up unless i give it power...
Old Dec 7, 2008 | 04:54 PM
WolfPack's Avatar
Have you checked all the ground cables and connections to make sure its all tight?
Old Dec 7, 2008 | 05:33 PM
Is that 500RPM in neutral? If so, that seems very low.
Old Dec 7, 2008 | 06:16 PM
WolfPack's Avatar
Kyle mine idles around 600 rpm once its warm. Cold start idle is just under 1k
Old Dec 7, 2008 | 07:34 PM
550-650 is the normal warm idle speed. 500 would be low enough to drop alternator output by quite a bit. Maybe "very low" was a poor choice of words.
Here is a plot of alternator output (%) vs. RPM for cold and operating temps:
As you can see, the last 50RPM serves a drop of 10% in output. With a 100A alternator, that is the difference between 20A output at idle and 10A.
But the battery being dead in the morning may be caused by a current draw on the system even after the key is turned off.
Old Dec 8, 2008 | 06:32 PM
PABlazer's Avatar
ya my cold idle is rough 1000RPM little higher or lower depending in the temp outside... but once its warm and in park or neutral it idles right around 500-600 RPM, cuz i checked it out today... yes all my grounds r tight... i'm gonna try and do the big three this weekend
Old Dec 16, 2008 | 12:12 PM
nbr1jackas's Avatar
nbr1jackas is an unknown quantity at this point
i just had to replace my cap and rotor. alot of moisture biult up inside when i opened the box for the new cap there was a piece of paper saying the=at the vent screens should be pulled out due to a faulty design truck starts now but the engine light is still on p0300
ladeedawdeedaw
Dec 14, 2010 03:14 PM
millertimee1
Mar 22, 2010 12:50 PM
PABlazer
Nov 30, 2008 10:42 PM
rustyd
Sep 17, 2007 09:36 PM
rustyd
Sep 17, 2007 09:28 PM
