Blazer to Envoy
Good luck with the conversion, I think that a quick junkyard crawl will lead to what you need see..... if not to get parts at least get a feel for where and what you need and how to do it
i wan to do the same thing change my 95 to bravada front end. i want the headlights style and the bumper with the hook holds an fog lights in the same bumper. like the 98-up update but a bravada version? is the core support different on bravadas if i change to a bravada core support will the lights bolt uo and what bout the bumper?
I do not believe that a different radiator support is required. The pic with the HID Bulb & Ballast was to show the OEM HID set up and would not be included. The ballast mounting bracket in not included in any of these pics. It bolts with a single bolt on the face of the radiator support and hooks underneath the bottom of the radiator support. I did not take any pics of the bracket as it is installed when i replaced my headlights that included new OEM HID Bulbs & Ballast. I would go to a local GM dealer to get a drawing for a 1998-2001 Envoy with HID Mounting Pate for the ballast. The mounting plate is a little tough to get in the right position.
For a 95 to use those parts, a new radiator support is most definitely needed. For the 98+ crowd to use those parts, they'll drop right in to the factory radiator core support. Blazer's will need the different bumper cover & grill to match up though.
kickme, I know for a fact that this information is out there in other threads.
i want to do the same thing what year blazer does the guy have and you say the raditor is the same. what year blazer and bravada u talking bout that the core support is the same. i got a 1995 chevy blazer 4door. is the rad core support the same for the 98-up Bravada? and once i take off my 95 stock front bumper will i have to change anything to make the bravda bumper it.
going to the junkyard Monday. heres my list
grille, front bumper, left and right headlight, raditaor core support, and maybe the headlight wire harness and plug.
is the Radiator core support on my 95 blazer bolt on or welded on?or is its both welded and bolted? what bout from a 98-up radiator? if its welded and i bolt it on is that safe?
Last edited by swartlkk; 07-17-2010 at 08:42 AM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
Luca1Blazer
06-13-2007 11:55 AM
