blazer wont start
Yes that is correct. Has the outer ring on your balancer slipped? Maybe checking with a piston stop is in order?
Ok so it's running and still throwing a p0300 could the balancer cause a multiple misfire code? Keep in mind I've replaced cap rotor and gear and crank and cam shaft sensor. Plugs and wires Also.
I always say to test the misfire detection system by monitoring the misfire pids for all 6 cylinders and inducing a miss on specific cylinders, one at a time. You would be surprised how screwed up the misfire detection can get. If it works properly when you induce a miss then it is fine. If it doesn't, then all bets are off for misfire codes being legit and the SES light staying off.
burnsdomain
08-11-2019 07:25 AM
robwatson
05-22-2013 05:40 PM
rkosu02
13
02-27-2011 06:53 PM
