Blend door actuator
Old 02-22-2016, 10:14 AM
Did you ever repair the broken piece in post #7?
  #22
Old 02-23-2016, 07:03 AM
Tajohns34's Avatar
I did not. I need to figure out what it is and order a new one. I will see if I can get a picture after work and post it. My fear is that I have to pull the dash to replace it.
  #23
Old 02-23-2016, 10:41 AM
Heater case will need to be removed and disassembled, right after you remove the dash
  #24
Old 02-24-2016, 10:59 AM
Tajohns34's Avatar
It was really hard to get a camera in there to take a picture. But there is a vacuum operated arm that is white plastic that the end is broken off of. It is just to the left of the blend door motor.
  #25
Old 02-24-2016, 06:10 PM
Slave door actuator linkage. You'll end up at the dealer or a boneyard, (GM only, not available aftermarket).
  #26
Old 02-25-2016, 07:07 AM
Tajohns34's Avatar
Ok, that helps a lot. I will see if I can snag one the next time I am at the yard. I will plan on replacing it this summer. Just out of curiosity what does that part do?
Thanks!
Kidkaos70
04-20-2011 11:35 PM
ravenhurst
02-16-2010 05:53 PM
stickemdano
11-14-2009 11:13 AM
markrd
05-08-2009 01:39 PM
Quick Reply: Blend door actuator
