blinker blinking
blinker blinking
Hi with the signal leaver in the neutral the left front signal flashes real fast and the back is not lit at all when I push the leave down for the left side everything works fine But when I move the leaver up for the right side its like putting the four ways on.
...start surfing junkyards for a new blinker stalk. New ones run $200+. But before you go and spend any money, check ALL of the fuses, and associated wireing, to make sure nothing is crossing. The fast blinking to the left side suggests a short in the system. Usually, when a bulb is out, the bulbs will blink fast. But since it is happening in the neutral position. What year? Does it do this when the cruise control is switched off?
I cut the hitch wires off and caped them checked bulbs and fuses couldn't find anything so i took the maltifuction switch out it was a worn and the 4 way was glued together not from me I'll get one on monday the wiring plug for it goes into a block on the colom does it just pull out is there tabs or is there screws i didn't want to brake it so i left it till i see the one from the weckers. thanks
blazintexas
05-01-2012 06:01 AM
allforenot
02-22-2007 12:04 AM
wick001
12-02-2006 10:05 PM
tambo
03-04-2005 05:44 PM
