Blower issue
Old Jul 15, 2020 | 01:52 PM
Mdz320's Avatar
Mdz320 is on a distinguished road
I back probed the one I replaced. Never above like 16 volts. When it cutout, like 2v.
Old Jul 15, 2020 | 01:55 PM
GeorgeLG's Avatar
16V, you have an alternator issue.
George
Old Jul 15, 2020 | 01:57 PM
Mdz320's Avatar
Walk me thru checking new blower please
Old Jul 15, 2020 | 02:01 PM
GeorgeLG's Avatar
With the truck running:
Voltage across the battery terminals
Voltage across the positive and negative blower wires as close to the motor as possible under full load
Same thing but move the negative probe to a good clean frame ground
Amperage if you have a meter. If clamp on then clamp anywhere on the power wire, full load.
George
Old Jul 15, 2020 | 02:02 PM
Mdz320's Avatar
Back probing with other probe at bat negative. 11 12 volts
Old Jul 15, 2020 | 02:07 PM
Mdz320's Avatar
George
Across bat 14
Across wires. 11
frame 11
No clamp
Old Jul 15, 2020 | 02:11 PM
GeorgeLG's Avatar
Originally Posted by Mdz320
Across bat 14
Across wires. 11
frame 11
No clamp
If these numbers are at full load then you don't have a ground problem.
What was melting before?
Do you have an ammeter function on your meter? If so try to get a current reading inline under full load if you have a 10A scale
George
Old Jul 15, 2020 | 02:15 PM
Mdz320's Avatar
The relay melted. I checked my old post. The high speed wasnt working.
Here is what i have. Clamp seems to not work for vehicle power unless im misunderstanding it.
Old Jul 15, 2020 | 02:21 PM
Is it just me, or is that switch to the "off" position...
Old Jul 15, 2020 | 02:22 PM
Mdz320's Avatar
When I took pic. Yes
