Blower works intermittently.
I have a 98 Jimmy with climate control. My blower will work sometimes for days, then not work for a day or so. I have tried all settings, manual, automatic, switched to a/c with no luck in getting it going. Then next day it will start again. Any help will be greatly appreciated, as it is cold up here.
Thanks
Thanks
i had the same problem once in my pontiac grand prix and it was my blower switch had a short i put in a new switch and problem solved you can check it with a continuity tester
What were you looking for with the tester?
You are likely experiencing a bad blower motor. Next time it doesn't start, try hitting the blower motor case under the hood near where the passenger fender meets the firewall.
Thanks swartlkk. I will try that next time it happens and let you know.
Check the ground wire that comes off your heater control module. 2 wires plug into the blower motor and the 3rd wire goes to the right of the plug on the blower motor. Make sure the 3rd wire is tight making good contact.
The blower finally quit again. Beat it and it started. Changed blower out, so far everything is OK. Thanks everyone for your help.
I have a 2003 4 door sedan 1FAFP53U43A253683 EMW2351 I just sit in the car and press any button with in 20 seconds and that programs the car keyless remote?
whats this gotta do with this thread? please make your own thread for this topic
thanks
tred5357
06-04-2011 11:23 AM
byrm31
12-06-2010 06:43 PM
azaviator
04-08-2010 08:04 PM
