Brake Booster Vacuum Line Leak?
So the other day, I guess I had a lean missfire that shot off the brake booster line from the engine. Once I figured out it was that, it looked like all I has to do was just put in back in by matching the tabs, instering, then twisting. But ever since then it sounds like a air hiss from that hole, my car is ultra sluggish from a stop to acceleration, and when I turn off the engine when the hood it open about two seconds after the engine is off the hissing goes away too. Is there a type of sealant or maybe o ring that should be in the port on the engine that holds the line on or am I missing something?
Does this look like the part that you're referring to? Dorman - Help PCV Valve 47026: Advance Auto Parts
