Brake Job and Front Axle Replacement
Old Feb 27, 2012 | 06:03 PM
LannyL81's Avatar
Originally Posted by bernie11
Wanted to know if anyone had any instructions for replacing the front rotors and shocks on a 1999 Chevy Blazer 4x4? Is there a trick to getting the old rotors off? Also about getting the new front shocks back on? Thanks
If the rotors are rusted in place on the hubs...then try the WD-40 or PB Blaster, etc and as long as the rotors are going to be replaced....just hit them with a hammer on the inside surface and work them off the hub.
Front shocks are no trick....be sure to put a jack under the control arm to help out.
Old Feb 28, 2012 | 05:39 AM
coolasice's Avatar
coolasice will become famous soon enough
on the shocks... i put my shocks back in prior to cutting the shipping strap... bolt in the top, then cut the strap and guide the bottom into place, use a large screwdriver or small prybar to push up enough to insert the bolt.
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
kiwiblazer
Jun 19, 2010 03:00 AM
rriddle3
Sep 4, 2007 01:11 PM
bmxracer182
Jan 24, 2007 01:49 AM
