brake system troubleshooting!!
Old Jun 28, 2007 | 06:27 PM
juscarter's Avatar
juscarter is an unknown quantity at this point
Default brake system troubleshooting!!
Recently I began to notice a sort of wobbly/heavy vibrating going on in my front braking system. Normally i would say that the rotors were going, but the symptoms aren't consistant. Sometimes I won't feel it for days, other times i feel it every time that i brake. Then intensity with which it occurs varies as well. Im thinking that it may be an axle problem, but really have no clue because i've never dealt with an axle prob before. Please help. I dont want to end up on the pavement!!
Old Jun 28, 2007 | 08:22 PM
hillbillyinOhio's Avatar
Default RE: brake system troubleshooting!!
I would check fluid level first, and then maybe when you are heating up the rotors, you are noticing the the wobble. might be a little warped!
Old Jun 29, 2007 | 01:47 PM
juscarter's Avatar
thanks boss. I'll def check into that. The brake fluid level is fine, so maybe you're right on the warped rotors.
schimmi021
May 16, 2011 01:52 AM
crasy
Oct 17, 2009 08:45 PM
mlonas
Jun 25, 2008 10:01 PM
grdylan
Jun 5, 2007 05:27 PM
z28chic
Oct 24, 2006 04:37 PM
