brakes and dying
brakes and dying
ive recently started having this problem where i go to push on my brake and its really stiff. and when i do apply my brakes at a light the car stutters and occasionaly dies. any solutions would be greatly appreciated.
check the rubber hoses, make sure they are in good condition and not cracked/falling apart.
If worst case you may need to replace it, I have another hard drive for my laptop with my GM manual loaded, I can look it up if needed (does not run well on vista )
Yes, if it leaks vacuum you will not get the assist that gives you power brakes. Check the big hose going to the booster and the check valve at the booster but if the engine only runs rough or dies when you step on the brake the leak is inside the boster. If so you need to replace it as repairing it is not a simple task.
Dyspayre
09-06-2012 03:01 PM
wallacereid
13
05-08-2012 12:30 PM
pfunknasty
04-23-2012 10:36 AM
