broken-off allen heads on front caliper.
Old Aug 10, 2010 | 09:33 AM
racsan's Avatar
racsan is on a distinguished road
Default broken-off allen heads on front caliper.
well my '97 has a interesting issue. when dad owned it he was doing front brake pad replacement and on the right side the allen slider pin that the caliper rides on broke off. he had already done the left side and must have forgotten about the right side. i found it while looking it over and i broke off the other one trying to get it out. im thinking i need to heat the knuckle where the threads are and try and turn the stud with vise-grips, but i was wondering if anyone else has had this happen to them. im about to go out to the "parts" rig (a '94) and see what i can get apart on it. any thoughts, ideas or experiances? thanks.
Old Aug 10, 2010 | 11:50 AM
abig84's Avatar
Sounds like a plan. Maybe soak it with pb blaster for a while then heat it up and grab the pins. Can you get at the pin? Might have to cut the caliper off
Old Aug 11, 2010 | 12:03 AM
racsan's Avatar
got the right side of the "parts" '94 apart, so at least i'll have a useable knuckle, looks like i'll probly need a new caliper, putting heat on the knuckle where the pins thread into destroys the piston dust seal. i probly need new cailpers anyhow.
Old Aug 11, 2010 | 12:07 AM
New calipers aren't all that expensive and the pins are part of the hardware kit that includes the boots as well.
Originally Posted by racsan
saw where my model could have either a single piston or 2 piston caliper on the autozone site. wonder if theres any difference in the knuckle between the single/dual piston caliper? i know mine is the single piston, but if the 2 piston will bolt right in, that could be a nice upgrade.
Answered. Please try not to double post your questions.
Old Aug 12, 2010 | 01:39 AM
racsan's Avatar
managed to get the bolts out without ruining the caliper and didnt need the knuckle i got off the parts truck. but better to have parts ready then to have to scavange them if things go bad. i did use new bolts for the caliper.brakes are no place to use used hardware.
Pyro_fighter
Oct 31, 2012 07:58 PM
warthogdriver
Jun 30, 2011 07:17 PM
monette999
Oct 16, 2010 01:26 PM
carterx
Apr 17, 2010 06:55 AM
Bob_55
Mar 29, 2010 11:32 AM
