Bypass 4WD module?
Old Dec 24, 2008 | 09:26 AM
batswinger's Avatar
batswinger is an unknown quantity at this point
Default Bypass 4WD module?
Hello, I have a 99 blazer 4WD 4.3L automatic. My 4WD module is not working (broken connector pins) so while I'm waiting for a replacement connector is there any way to bypass the module and force the truck into 4W-HI? Tons of snow and driving in real wheel only is not fun!! I have the module pinout... what signal can i jumper to force the system into 4WD?
Old Dec 24, 2008 | 09:30 PM
Default RE: Bypass 4WD module?
Sorry to ask such an obvious question, but have you tried to straighten the pins?
Other than that, what transfer case do you have? 3-button, NP233 or 4-button Auto4wd NP236?
Old Dec 24, 2008 | 11:31 PM
WolfPack's Avatar
Couldnt you just pull the actuator cable and clamp it off? keep it locked in?
Or is the problem here in getting the transfer case into 4hi?
Old Dec 25, 2008 | 09:41 AM
I read it to be that the TCCM connection had bent pins which would mean that none of the system is getting engaged, not just the front axle.
LesMyer
Jun 15, 2015 10:29 AM
dharvey4651
Feb 16, 2013 09:02 PM
IanD
Nov 21, 2012 06:06 PM
codemanrose
48
Feb 22, 2010 09:56 AM
94 blazer
Engine & Internal
Dec 19, 2005 12:50 PM
