A/C ACUMULATOR PRESSURE SWITCH REPLACEMENT
No. Any of the sensors on the back of the compressor require that the system be evacuated, but the low pressure / cycling switch located on or near the accumulator does not require the system be evacuated to change. It has a check valve that will prohibit the release of the refrigerant from the system.
You will want to have a new o-ring if it doesn't come with the replacement switch. You will also want some PAG oil to use as a lubricant for the new o-ring. Once you get the old switch out, clean the sealing surfaces with a clean, lint free cloth.
chevybaby97
Jul 23, 2011 04:48 PM
Spartan66
Jul 11, 2008 02:34 PM
acarlson
Jul 19, 2006 01:09 AM
1995, 2000, 97, ac, accumulator, air, blazer, change, chevy, conditioning, cycling, pressure, replace, replacement, switch
