a/c recharge
Old Jun 18, 2007 | 01:49 PM
blazerlt01's Avatar
blazerlt01 is an unknown quantity at this point
Default a/c recharge
hey guys, after some time off, i'm back!! lol but in all seriousness, my friend has a 97 blazer, ther a/c needs to be recharged, i need to know how much of the freon to put into the system. thanks
Old Jun 18, 2007 | 01:58 PM
Default RE: a/c recharge
If you are applying a vacuum to the system, it should take 0.80 kg (1.8 lb.) of R134a and depending on what you need to replace, you'll need to add in the specified amount of PAG oil.
Accumulator - 60 ml (2 fl.oz.) + the amount drained
Compressor - if less than or equal to 60 ml (2 fl.oz.) removed, add 60 ml (2 fl.oz.). If more than 60 ml (2 fl.oz.) add the amount removed
Compressor Suction/Discharge Hose - 30 ml (1 fl.oz.)
Condenser - 30 ml (1 fl.oz.)
Evaporator - 90 ml (3 fl.oz.)
Hope this helps!
Old Jun 18, 2007 | 07:51 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
You should be able to buy a refill kit from like Advance Auto parts or Walmart or anywhere, which would have the proper amount of oil, leak stopper, and freon in canisters. It also comes with a gauge andfiller connections and most likely instuctions on how to use it. It worked great for me I think I used Arctic Air or something like that.
-Lenny
carterx
26
May 25, 2014 12:00 AM
Jello0123
Jun 11, 2009 01:34 PM
abadinalbany
Jun 1, 2009 08:27 PM
brf2
May 19, 2009 07:56 PM
hockeykid15
May 7, 2007 10:02 PM
