Can Someone recommend a good hub bearing?
Old Aug 14, 2012 | 05:13 PM
ZR2Winnebago's Avatar
ZR2Winnebago is on a distinguished road
Default Can Someone recommend a good hub bearing?
Ok, so about 2 years ago I replaced my right front hub bearing because it was shot. I used Timkin. I am now sitting with Low speed ABS activation because the sensor is out of spec. (it's reading 887 ohms and my book calls for 1125 - 1400 ohms). It kinda chaps my a%% because the bearing is fine but, I almost rear ended someone today so enough is enough.
Old Aug 14, 2012 | 05:23 PM
warthogdriver's Avatar
if you just need the cable check local yards...they can be swapped out.
in the mean time you can disable the abs..you will get the dash light though..
edit:
have you tried to clean them up at all? somtimes corrosion gets in there and messes with the offset of the sensor to the exciter ring
i have a 99 and i have a collection of cables because i chew up hubs.
let me know if your interested. i can send ya a couple. if you in the lower 48 it would be worth it but if you in canada the shipping would be prohibitive.
i dont see why the 99 cable and the 00 cable would be diff.
Old Aug 14, 2012 | 08:42 PM
4x4blazerguy's Avatar
I guess I missed something here. Do you have an ABS Light on? If an ABS sensor isn't working it should throw a light & the system should go into normal brake mode. I'm not following almost rear ending someone. The brakes should work as normal brakes without ABS, at least mine do & have on my 98. Replacing the sensors is common but also di-electric greasing the connections helps. including into the ABS Unit.
xgiovannix12
The Chop Shop
20
Jul 23, 2011 01:11 PM
blacer2000
Sep 5, 2010 09:01 AM
midnightbluS10
Feb 10, 2010 11:04 AM
nflea7
Aug 25, 2007 09:15 PM
greengoose89
Aug 3, 2006 07:32 AM
