Charcoal canister problem
Old 04-25-2015, 07:27 PM
Should be three wires on the positive alternator stud. 1 black and 2 blue fuse links. The pigtail from the stud to the fuse link might be red, can't remember for sure.
Old 04-27-2015, 10:27 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
Ok Thanks
Chuck I have that wired correctly.Now can somebody tell me where this plug in goes to?The harness connected to it is about 4ft long,Im thinking it goes to the transfer case possibly?
Attached Thumbnails Charcoal canister problem-jimmy-harness-plug-.jpg   Charcoal canister problem-plug.jpg
Old 04-27-2015, 05:52 PM
What color are the wires? I might be able to check the schematics and figure it out from that. Or, follow the harness back and see what it connects to, that might be a clue. My guess is that it goes to the neutral safety switch on the transmission, but it's just a guess
Old 04-27-2015, 07:51 PM
Everything on the neutral safety switch has been connected.If you zoom in on the pic of the plug the wires should be there to get a look at.
Old 04-27-2015, 09:07 PM
Too fuzzy, can't tell all of the colors.
Old 04-28-2015, 07:51 AM
El_Beautor's Avatar
The altenator connections on my 96 are the same as Captain Hook described above. As for the plug, I have no idea off the top of my head. Good luck.
Old 04-28-2015, 08:46 AM
Question
Is there diagram of the engine harness to be found that shows where this plug goes?
Old 05-03-2015, 06:00 PM
Question
That mystery plug problem has been solved,it plugs into the front transfer case axle.
Now I have a new problem,everything is all wired up but when I turn the key all I get is clicking noise.Yes the battery is new and started has been tested good.The engine can be turned over by hand.Im at a loss of what to do next?
wazzledoozle
06-04-2011 05:14 PM
Squad-6
05-21-2011 02:23 AM
puckrocker
03-02-2011 02:01 PM
slk34
07-05-2009 01:29 PM
jphayes921
04-05-2008 07:25 PM
Quick Reply: Charcoal canister problem
