clicking sounds in passenger side dash
Old Oct 25, 2010 | 09:02 PM
gnpower's Avatar
gnpower is an unknown quantity at this point
Default clicking sounds in passenger side dash
I have a '98 Blazer that has some clicking sounds coming from the passenger side dash. Sounds exactly like a blinker clicking, but much quicker and much more random. Not sure what it is, but sounds like I would have to take the dash apart to get at it. I was told it was a very common problem with the model. Anyone know how to fix it?
Old Oct 25, 2010 | 10:02 PM
Common. "clicking+under+dash" should return discussions with solutions.
Old Oct 26, 2010 | 07:23 AM
gnpower's Avatar
My clicks sound like a blinker, but my blinkers nor my hazard lights flash when it's making the noise. Would my issue still be a hazard switch repair?
Old Oct 26, 2010 | 01:58 PM
Denominator's Avatar
Denominator is on a distinguished road
Probably not the same problem, but it sounded similar.
Here is my solution to the clicking : https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/hahaha-inside-dashboard-noise-back-49484/
Old Oct 30, 2010 | 07:00 AM
-Z-'s Avatar
-Z-
-Z- is on a distinguished road
im having the same exact problem if you open the glove box you can access the combo flasher you can actually feel the clicking through this tried replacing it but didnt fix the problem does your air bag light come on and off whenever it wantsfor different lenghts of time my temporary solution was to take out the sir fuse from the fuse box on the side of the dash no more random clicking but the air bag light stays on doesnt bother me since my air bag light was always coming off and on but such a relieve not to have the annoying clicking sound im going in a few hours to the junk yard to find a new impact sensor to see if that is a permanent fix but pull your fuse and see if it stops your clicking lkie mine
Old Oct 30, 2010 | 07:31 AM
hunter01's Avatar
hunter01 is on a distinguished road
Default Clicking under passenger dash
I had this problem in my 99 blazer . The turn signal switch had worn and needed to be replaced. This eliminated my problem.hope this helps.
Old Nov 28, 2010 | 09:29 AM
gnpower's Avatar
I replaced the multi switch in the steering column and that fixed the issue. I tried cleaning it first, but it didn't help.
Bigjoe1986
22
Dec 2, 2015 04:29 PM
upmaine
Jul 9, 2012 12:31 PM
Holtsvillefd69
22
Feb 24, 2012 11:01 AM
apekim
Sep 15, 2007 10:46 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
