clunking
Old Mar 6, 2012 | 07:35 PM
iloveblazers's Avatar
iloveblazers is on a distinguished road
Default clunking
For the last week or two i have heard a clunking noise from the driver side rear tire every time i hit a bump. Today I replaced the rear shocks hoping that was the problem (one shock was bad the other was good but i replaced both).
When I was done replacing them i took it out for a test drive just to hear the clunking noise is still there. I looked at the leaf spring, i didn't see any cracks or chunks missing.
Any suggestions would be very helpful
I have a 98 blazer 2 wheel drive.
edit: forgot to add some stuff: I did notice when looking at the leaf spring that while looking at it from the side of the car. On the right side of it before you get to the part where its bolted down. There is a rubber piece and right along the rubber piece there is a tiny strip of steel (my guess, could be wrong) that is broken off on one side.
My uncle looked at it and said that it wasn't a big deal.
looked at the U bolts they look tight but I'll check that tomorrow. When i bought my car, it didn't have a jack so i bought a small hydrolic one that just sits in the back. The spare tired isn't loose.
I should also have mentioned that I had 500 lbs of pebble stones in the back for added weight in the winter. I took out all but 150 lbs when the clunking started.
Old Mar 6, 2012 | 07:58 PM
coolasice's Avatar
coolasice will become famous soon enough
sway bar? brake bracket/caliper nice and tight? leaf isolators in good condition? leaf bushings?
Old Mar 6, 2012 | 08:29 PM
sway bar is good and tight. I did notice when looking at the leaf spring that while looking at it from the side of the car. On the right side of it before you get to the part where its bolted down. There is a rubber piece and right along the rubber piece there is a tiny strip of steel (my guess, could be wrong) that is broken off on one side.
My uncle looked at it and said that it wasn't a big deal. Sorry should have posted that in the original post.
Old Mar 6, 2012 | 08:31 PM
war00's Avatar
war00 is on a distinguished road
check to make sure your u-bolts are tight
Old Mar 6, 2012 | 09:04 PM
blazerls1999's Avatar
blazerls1999 is on a distinguished road
Spare tire loose?? Jack is tight in the holder in the quarter?? Had problems with both of these.
Old Mar 7, 2012 | 01:08 PM
war00's Avatar
jack it up in the rear and ckeck for play in the axle bearings
tankie88
18
Jan 27, 2006 05:33 PM
user 1016
Jan 20, 2006 01:19 PM
Blazin 4x4
Oct 23, 2005 06:11 AM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
BlazerLS95
Jan 15, 2005 06:47 PM
