Clunking noise from engine compartment
Old May 27, 2013 | 05:35 PM
Regina Ball's Avatar
Regina Ball is on a distinguished road
Default Clunking noise from engine compartment
I have a 1997 chevy s-10 blazer, 4- wheel drive. My truck runs fine, it doesn't overheat, no dieing or stalling out. the noise at first sounded like crickets when your in the truck, then a sound like water flowing but muffled. Now when you open the hood and start it it sounds like clunking, or grating metal. ANY ONE HAVE ANY THOUGHTS ON WHAT IT MIGHT BE???????????????
Old May 27, 2013 | 10:08 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Either Alt,idler pulley or tensioner pulley bearings are failing. remove the belt and check for play on those pulleys you can usually spin the alternator and feel if it's not right..
Old May 27, 2013 | 10:56 PM
armykyle1's Avatar
armykyle1 is on a distinguished road
Leaning to tensioner pully as well.
Old May 28, 2013 | 01:12 PM
Thank you for the responses but- I have actually changed the upper tensioner and the carrier wheel. could it be my timing chain, how would i check to see if the chain jumped or stretched?
Old May 28, 2013 | 03:18 PM
4X4GS10B's Avatar
could be the alternator bearings going to bad, takey it off and take it to the auto part store and have it checked..
Old May 29, 2013 | 08:22 AM
Raybz's Avatar
Raybz is on a distinguished road
I agree with the alternator. Blazers are the only vehicle I have worked on that the alternator bearings fail before the brushes/rectifier. I have replaced mine and 3 others for friends/family in the past 2 years for the same reason
Old May 29, 2013 | 11:50 AM
richphotos's Avatar
Timing chains are not too common to go bad/stretch out on these, so I would rule that out. to find out if it is pulley related, remove the belt and start the truck *DO NOT LEAVE IT RUNNING LIKE THIS FOR MORE THAN A FEW SECONDS JUST LONG ENOUGH TO SEE IF THE NOISE STOPS*
If the noise stops, its pulley related, if it continues, start searching elsewhere
Old May 29, 2013 | 06:15 PM
cleburne red's Avatar
Pretty much exactly what I was going to say.
ktryan
Sep 24, 2009 05:28 PM
macdaddy25177
Jan 14, 2009 12:38 PM
GABlazer92
Mar 24, 2008 12:26 AM
nflea7
Aug 14, 2007 12:36 PM
thanser
Jan 28, 2006 08:50 PM
