Code scanner question
Can anyone recommend a scanner for OBD 1 that can clear the ABS pump like the GM tech 1 can. I need to get the pistions to the top of the module and bleed brakes. Most of the hydraulic parts were replaced, but the ABS and brake light comes on. I have a snap on MT2500, but it will not manual move the pistion on the ABS module. Any reommendations would be appreciated because I do not want to buy a tech 1 on ebay for $700.00, and no mechanic locally has this tool. Most recommended to take car to the stealership. The brakes work good, but those dame lights are annoying me.
Thanks
bizzs
Thanks
bizzs
It helps if you put in your location. I occasionally offer to help people with my tech 1 for various issues. I don't loan it out but I will hook it up a applicable vehicle and run diagnostics.
I have a tech 1 with the mass storage cartridge and can do the diag and clear out trouble codes with the abs. Bought a tech 1 specifically to troubleshoot and repair my abs system.
95LS
Apr 13, 2008 11:27 PM
