Column Shift Lever bend mod
Old Jul 27, 2011 | 08:28 AM
SoapyTheCat's Avatar
SoapyTheCat is on a distinguished road
Default Column Shift Lever bend mod
I've got an 02 Blazer 4X4, 4.3, Auto, column shift. Problem i've got and need to see if there is an aftermarket or easy fix to is...I've got my new KEYPORT key set. And it's slightly longer than my current key and keychains and sticks out past where the shift arm passes. A slight bend in the arm would give it more clearance. Has anyone ever had any experience with modifying the shift arm, or replacing with an aftermarket that has a differnt bend angle? Or am I just asking for trouble tryng to put a slightly larger angle in the bend on the OEM?
Old Jul 27, 2011 | 12:52 PM
I don't see any problem with bending the shift lever. I would recommend removing the shift lever prior to attempting to bend it. You may damage the column if too much force is applied.
PaulO2288
Headers, Intake, & Exhaust
Aug 4, 2009 04:11 PM
phantom
Jun 5, 2009 05:23 PM
Blahman20
Nov 3, 2008 09:45 PM
blazerstreetrod78
Jun 12, 2008 02:01 AM
guillermoariast
Oct 15, 2007 07:23 AM
