Coolant leaking from the left-rear side of the engine. Help!
Old Jan 1, 2012 | 09:04 AM
  #21
antman94's Avatar
antman94 is on a distinguished road
****! I just did my intake gasket yesterday and I tightened it to 35 Ft lbs. I tightened according to the 1994-1995 specs and I have a 2001! To top it off, I didnt buy the gasket with the T in it so its another plastic... Im an Idiot!
Old Jan 1, 2012 | 10:40 AM
  #22
pettyfog's Avatar
I feel your pain... and especially your problem with the 'What do I do NOW?'
If it were me, and 35 ft/lbs...
1. Keep fingers crossed and save the shekels to do it again in 6 months.
Second choice: Keep close eye on it and leave it alone till it leaks.
Note that's sort of a finger in the wind thing based on what I know as writ in my last post.
When/if you redo it, you might want to consider just going ahead and doing head gaskets at same time. IMO, more likely to stress them than the crank bore alignment.
Old Jan 1, 2012 | 10:48 AM
  #23
As PF stated, you either can pull it apart and inspect the gaskets for damage, replace as necessary, or keep a close eye on it and hope for the best.
If you didn't break off any of the bolts and you used the newer metal framed gaskets, the potential for problems is reduced to a point.
Old Jan 1, 2012 | 12:27 PM
  #24
antman94's Avatar
Fingers are staying crossed! Have about an hour of drive time with no apparent problem yet. I think I only got 1 out of the 8 bolts actually down to 35 lbs because it felt ridiculous cranking it that tight. Now that I think of it, Thats when I shouldve checked the damn book!
janddcunningham
Dec 6, 2013 06:10 PM
ezzieleach
Jul 23, 2013 12:10 AM
bertrenolds
Mar 27, 2011 11:04 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
kiwi
Nov 6, 2009 10:45 PM
