Crazy question
Old Nov 6, 2011 | 08:11 AM
mross45640's Avatar
mross45640 is on a distinguished road
Default Crazy question
I have a 99 blazer and need to put fluid in for rear wiper washer where in the world is its tank?i can hear the pump run but can't find it thanks
Old Nov 6, 2011 | 08:15 AM
It uses the same tank as the front wiper. The pump is mounted near the pump for the front, but slightly higher.
Old Nov 6, 2011 | 09:13 AM
mross45640's Avatar
Hmm I can hear it running but no fluid out back
Old Nov 6, 2011 | 10:46 AM
bromanjr's Avatar
bromanjr is on a distinguished road
As swartlkk stated, The pump for the rear washer is mounted higher in the reservoir so that the rear will stop spraying as the level goes down but the front will still work until empty.
Check the fluid level, start with a full reservoir and then check at the pump for pressure. Then you can follow the tube to the right side firewall, think there is a connection there you can check for fluid while pumping. Not sure of the routing from there, probably down in the passenger side door sills.
A common problem is the hose coming apart at a coupling inside the liftgate, you will see a flow of fluid out of the inside of the lifgate after a bit of pumping if that is the problem.
Old Nov 6, 2011 | 11:23 AM
mross45640's Avatar
I know it's completely full just filled it so I'll start checking with pump pressure thanks
Old Nov 6, 2011 | 12:37 PM
98blazin's Avatar
98blazin is on a distinguished road
on mine, i have to press the button for 4-5 sec before it gets to the rear and start spraying... maybe youre not holding the button long enough ?
Old Nov 7, 2011 | 04:50 PM
mross45640's Avatar
Got home from work today,checked fluid level was low I filled it completely up hit the button and after few seconds saw it pouring out on right side rear near headliner,popped trim apart it had came unconnected but here's the kicker it is too short to go back together the one side has the rubber connector and other side still has the bib on it but about 1 inch too short gonna pop it off and go to autoparts store and get some new line. Thanks for the help
Old Nov 8, 2011 | 12:36 PM
mross45640's Avatar
Ok I got the line back together but it stilled leaked plastic line is cracked I cut the crack out and replaced with a piece of vacuum line but is now leaking at the vacuum line any ideas?
Old Nov 8, 2011 | 09:51 PM
Tailgator's Avatar
Tailgator is on a distinguished road
Try rubber cement,elect tape or heat shrink
Old Nov 8, 2011 | 10:19 PM
Kknd310's Avatar
Kknd310 is on a distinguished road
theres a little black one-way valve that is used so the water doesnt flow back to the front of the vehicle, take it out and blow into it. it might be clogged, mine was and i had the same problems
powwowblazer
Mar 22, 2006 06:07 PM
zero psi
Mar 21, 2006 10:50 PM
m00nwater
Aug 23, 2005 09:22 PM
BOSTONGEORGE
Jun 24, 2005 12:40 PM
