Cruise control fuse keeps blowing.
Old May 26, 2012 | 08:36 AM
billfrank85's Avatar
billfrank85 is on a distinguished road
Default Cruise control fuse keeps blowing.
The 10A cruise control fuse keeps blowing in my 98 Jimmy. If I replace it, it'll work fine for a few days and then blow again. Is there anything else that shares the same circuit that might cause this to happen?
Old May 26, 2012 | 09:39 AM
pettyfog's Avatar
ABS does on my 99
output from fuse goes through normally closed brake sw {opens when brakes applied}
Check for rubbed wire around there.
Old May 26, 2012 | 09:54 AM
I will check. My ABS light is on and the system is not functioning as well, would that be another possibility?
Old May 26, 2012 | 12:33 PM
pettyfog's Avatar
Depends on the code stored. If it's a system problem, perhaps. Not real likely, though.
Most likely to be a rubbing wire, bad switch or faulty cruise servo.
To find out if it's that circuit, next time it blows fuse, use meter on the test pins top of fuse to find 12v, then on the other side of fuse, use ohms to see if the brake switch affects it
You didnt say if you just find cruise doesnt work, or if all of a sudden cruise stops working while engaged
AustinBlazer
Jun 4, 2013 10:35 AM
rxhvn
Dec 17, 2009 08:03 AM
Garv
Jan 5, 2007 06:35 PM
f2fire
Jan 5, 2007 09:06 AM
live4camaros
Jul 12, 2006 01:24 PM
