CV Axle Assembly Replacement
If anyone has read a posting about being able to pull the CV Axle Assembly throught the spindle by removing the wheel bearing....IT DOES NOT FIT.
I replaced the driver's side CV Axle Assembly and also found the lower ball joint pretty shot. I could not get the lower ball joint to separate, so I removed the ball joint bolts and took the spindle off and then I was able to get the ball joint out.
When I had everything apart I thought I would try the CV Axle Assembly through the spindle...with bearing removed...NOPE....IT DOES NOT FIT.
Just passing along information.
Oh and getting the CV Axle Assembly out and back in.....is a chore!!!
Yep. I learned the hard way too.
+1 , does not fit through the spindle... but mine was a peice of cake to remove and re-install in the diff.
cbur307736
05-05-2011 07:27 AM
KLBlazer07
13
01-14-2007 04:16 PM
