Deeper transmission pan/ trans filter question
Old Oct 11, 2012 | 10:49 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Originally Posted by JRP22
i know this post was from a long time ago but is that pan still available? or can you lead me to where i could get one? if i have to ill get one at autozone but is it for our trucks or just a 4l60e in general? just wondering what i should ask for at autozone if i do end up going there. i mostly want it for the drain plug i think it would come in great handy to do a drain and refill what has drained on my own. thanks in advance sorry about posting a while later but i was just doing some thread searching and found this
4L60E pans should be the same between the S-10 and full size trucks. eBay has them in different styles, but I recommend the one with the "smooth" but stepped bottom that is OEM style on trucks. It adds about 2 quarts of fluid and you need the deep pan filter so it picks up fluid along the bottom of the pan properly. Just make sure it has a drain plug. Then go to Autozone with the pan and ask them to give you a magnetic plug that fits it so it will pick up particles better. 4l60e deep pan | eBay
Autozone MAY have them, but they might be overpriced and I didn't see the Dorman pan on there that is OEM style. Might just be the performance/aluminum pans which are alot of $$$.
EDIT: ADVANCE has the pan I have, but it is more expensive than when I got it 2 years ago: http://shop.advanceautoparts.com/web...ansmission+pan
Old Oct 12, 2012 | 04:49 AM
coolasice's Avatar
coolasice will become famous soon enough
Old Oct 12, 2012 | 12:15 PM
neo71665's Avatar
I have the summit branded cast aluminum with fins on mine. I run the blazer in mud and slop so if it gets in the trans someway ill change it but other than that I only change the fluid once a year, filter every 2 years. Most of the time I just do it in march or april when it warms up and is dry enough, no set mileage or anything like oil changes.
globalaccessacc
Jul 5, 2013 04:08 AM
ElevenevelE
May 4, 2012 12:15 PM
xgiovannix12
Sep 10, 2011 08:52 PM
taba5
Dec 7, 2009 06:27 AM
blazerJim1701
Aug 28, 2009 11:50 PM
