Question about removing trans pan from a 2001 Blazer 4X4 LT
Old Aug 22, 2009 | 01:42 PM
blazerJim1701's Avatar
blazerJim1701 is an unknown quantity at this point
Arrow Question about removing trans pan from a 2001 Blazer 4X4 LT
I just bought a pair of used ramps on craigslist for 20.00 and I put the blazer up on them before to see how much of a pain it is to change the tranny filter.
It doesn't look that bad...
BUT one question.
It looks like there is linkage and the linkage in held by a mount that is held with 2 bolts but one bold is above the cable.
how do I get to that bolt to get it off?
Thanks
Jim
Old Aug 22, 2009 | 08:01 PM
I have just pushed the cable to one side before and used a 1/4" socket w/ extension. If that does not work, a crow's foot socket will get to it no problem.
Old Aug 27, 2009 | 10:30 AM
what is a crows foot socket?
Old Aug 28, 2009 | 05:09 PM
Google.
It is a special socket (some call it a wrench) that basically looks like the end of a wrench, but has a square hole in it to be used with a ratchet.
Old Aug 28, 2009 | 11:50 PM
AJBert's Avatar
There should be enough flexibility in the cable to move it out of the way to get a socket on that bolt. If not, you may have to loosen/remove the next bracket in line.
Just make sure you have a LARGE pan once the pan lets loose and you aren't laying underneath the pan.
ComputerNerdBD
Oct 12, 2012 12:15 PM
dmc919
13
Mar 29, 2010 11:16 PM
taba5
Dec 7, 2009 06:27 AM
bigwes
Jan 20, 2009 01:00 PM
dmndeacon
Jan 20, 2007 12:46 PM
