DIY transmission fluid exchange, which one do I remove
Old Jul 24, 2013 | 02:31 PM
billfrank85's Avatar
billfrank85 is on a distinguished road
Default DIY transmission fluid exchange, which one do I remove
Wanting to do this soon. Got the clear tubing and container, which line do I take off of the radiator to do the fluid exchange? 01 Bravada. Also, how much ATF should I plan on getting? Will be running the fluid out until it turns bright red.
Old Jul 24, 2013 | 03:17 PM
Twip's Avatar
so you arent changing the trans filter then?
and how do you plan on getting the new fluid in the trans while its spitting out the old fluid?
i just did mine and it took 5 quarts but i pulled the pan and changed the filter. if you are going to do it the way that you are talking about, i would buy more than 6 quarts. you can always return what you dont use.
Old Jul 24, 2013 | 04:00 PM
I dropped the pan and changed the filter already, along with replacing the 5 or so quarts of ATF I drained off. This was about a month ago.
The idea is to watch how much fluid comes out and refill it through the dipstick tube at an even ratio.
error_401
May 3, 2009 06:06 AM
john01blazer
Jun 19, 2008 04:39 PM
redneck_mechanic_187
Headers, Intake, & Exhaust
17
Jan 11, 2007 07:26 PM
Oct 21, 2006 11:41 AM
truck608
Apr 26, 2006 11:22 AM
