Do I have an idler pulley that will fit my blazer?
Old Aug 22, 2018 | 11:11 PM
vfeichten's Avatar
vfeichten is on a distinguished road
Default Do I have an idler pulley that will fit my blazer?
Hey y'all
I ordered an idler pulley from amazon:
Amazon Amazon
regarding the product description I thought it will fit in my 2001 V6 4.3 trailblazer with A/C
When I took out the idler pulley that was installed, I realized that they have a slightly different shape and the old one has this Nr. written on it:
0 1 25702W (nothing else)
When I try to find anything regarding this serial No online, I can't find anything.
Do you guys think the product I ordered can be installed or do you know where I can get a pulley that will fit?
Thanks
Old Aug 23, 2018 | 12:44 AM
Mike.308's Avatar
As far as I know, the difference lays in an outer diameter. If the diameter match, then You got the correct one.
Old Aug 23, 2018 | 04:53 AM
dlundblad's Avatar
dlundblad is on a distinguished road
As Mike said, just make sure the diameter is correct. Maybe measure the back of the pulley to a feature on the engine and compare that to the new part as well?
I just replaced with pulley bearing with an 302ff bearing. $4 or so.
Old Aug 23, 2018 | 06:19 AM
I dont think you have the right one. The center hole for the nut looks too small
Old Aug 23, 2018 | 06:21 AM
Old Aug 23, 2018 | 09:46 AM
Old Aug 23, 2018 | 10:03 AM
Mike.308's Avatar
Exactly. Your perceptivity is better than mine.
Old Aug 23, 2018 | 12:28 PM
vfeichten's Avatar
Thank you guys!
Old Aug 25, 2018 | 05:32 AM
I have repaired my idler pulleys two times. It's a simple standard bearing which can be easily pressed out and a new one in. Just make sure about the position of the bearing.
Czechman90
Sep 30, 2019 05:32 PM
metalmeltr
Feb 5, 2014 09:37 PM
dbaas
Nov 3, 2010 01:09 PM
fondo
May 22, 2010 07:04 PM
truesmack
Oct 12, 2008 08:24 PM
