Door hinge
Old Dec 13, 2005 | 09:09 AM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Default Door hinge
Does anyone know where I can find a door hinge kit? The drivers side door has dropped down about 1/4 of an inch. This is making the door hard to close since the striker is no longer ligned up correctly.
I have changed the pins and bushings on another car and this allowed me to fix the problem without having to replace the entire hinge assembly.
I's a 99 4 door.
Old Dec 13, 2005 | 11:10 AM
Default RE: Door hinge
Hinge Pins and Bushing kits are available from any autoparts store. I would suggest you either find a friend at a body shop or buy the proper tool for the reinstallation of the hinge spring. The only place that I have been able to find the spring tool is from Eastwood.com. Specifically, Light Truck Door Hinge Spring Tool - #31202 for $15.29 +s&h. I spent the better part of 2 hours with a vice and some baling wire before I finally got the damn thing back in when I replaced the drivers door hinges on my Bravada (same body as your '99 Blazer).
Good Luck!
BTW, the hinges on the S-series pickups are not replaceable. They are welded in. Only the pins and bushings are replaceable! If they are allowed to go too far, where the holes in the hinge halves get worn... It's a pain in the **** to get it fixed...
Old Dec 19, 2005 | 03:46 AM
gatopescado's Avatar
gatopescado is an unknown quantity at this point
I bought the pins and bushings for my 2000 blazer at Pep Boys. The spring is a big b@#ch. I would say if you can get a tool to help with the spring it will be well worth it.
eo1davista
May 17, 2007 08:51 PM
Scream And Fly
Aug 23, 2006 10:29 AM
frankjc
Jun 13, 2006 12:28 AM
saxy37
Apr 25, 2006 01:22 PM
hstt
Mar 4, 2006 12:03 AM
