door hinge issues
Old May 15, 2007 | 01:08 AM
eo1davista's Avatar
eo1davista is an unknown quantity at this point
Default door hinge issues
i've got a 2004 Blazer 4dr 4wd ls package and the door hinge had a ceramic bushing in the hinge pin to prevent the scweaking sound everytime you open the door, well it broke off and the hinges are welded in, is there an easy fix to this annoying problem
Toby
Old May 15, 2007 | 01:22 AM
20Blazer00's Avatar
Default RE: door hinge issues
As long as you get to it before the hole gets egg shaped to bad you can get a hinge repair kit on e-bay or local auto parts stores. The one kit i found uses bronze bushings instead of ceramic... but they still fail without proper care and maintainence...they cost about $8-$10 per door...body shops will charge $80 per door if you can't do it yourself...
Old May 15, 2007 | 01:29 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Yup, replace the bushings and pins NOW. Welded in hinges are not relevant.
Old May 15, 2007 | 08:18 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
buy stock in bush pins......you will replace them frequently.....not too hard to do though
Old May 17, 2007 | 08:51 PM
C5Longhorn's Avatar
C5Longhorn is an unknown quantity at this point
I"ve got this problem and the racket when I open the door is pretty annoying. I'm not sure what you are talking about though, parts wise. Any pictures of the problem and the parts solution? I can't tell exactly where the squeaking is coming from.
Thanks,
Rick
StartingLine25
Dec 8, 2010 07:14 PM
frankjc
Jun 13, 2006 12:28 AM
saxy37
Apr 25, 2006 01:22 PM
hstt
Mar 4, 2006 12:03 AM
tomsblazer
Dec 19, 2005 03:46 AM
