Drive without front cv axle's?
My 1997 LT Blazer has a bad right front CV axle with rumbling noise from 60KM/H....
I never drive in 4x4....good roads in Holland
Can I remove the 2 front CV axle's and drive it ?
Greet from Europe
Greet from Europe
sure you can remove the front diff also if you want, but you have to cut the boot on the cv and pull them apart where you put the nut on, and clean it then put it back on the hub and tight the nut. you can sell the front diff to someone
Since the axle nut torque is so critical to the life of the bearing, I would not recommend running without the CV shaft installed. If you really have to, then dismantle the CV shaft down to the outer stub and leave that mounted into the bearing hub assembly.
So if i cut the CV axle's at both sides and leave a piece about on the picture below it isn't a problem to drive the Blazer........
Alex Yost
May 26, 2013 02:00 PM
racsan
Jul 16, 2012 03:42 PM
lizzj70
Jun 23, 2010 06:57 PM
SanfordBlazer
Mar 2, 2009 06:37 PM
watsonracingteam
Aug 27, 2008 10:14 PM
