Drivers window
Old Aug 25, 2013 | 01:13 AM
step66's Avatar
Default Drivers window
Hello all! A few months back I had a stuttering rising of my drivers window,as I had a complete switch module on hand,I installed it(it was from a previously owned unit) All was well for only 3-4 months,same symptoms occuring now and no part in my stock. Do I at this point think motor or the failure of the replacement module I put in? I am leaning toward the switch module again,what say you?
Old Aug 26, 2013 | 10:22 AM
JayArr's Avatar
JayArr is on a distinguished road
I usually blame a stuttering window on the motor. Switches usually fail by not making contact or requiring several 'presses' before they contact, rarely have I seen them make contact then lose it then get it back while under load.
The drivers door motor always wears out first. To check it out without spending any money get 10 feet of lamp cord or speaker cable and take the door skins off both the drivers and passengers door and route the power from one to the other. One time I was really broke and I was able to swap the drivers door motor with the rear drivers door (4 door)(which had barely ever been used).
Old Aug 29, 2013 | 08:09 PM
switch doctor's Avatar
switch doctor is on a distinguished road
I had a window that did the same thing and ended up being the widow switch.
http://www.switchdoctor.net/chevrole...ow-switch.html 30 day return policy
suckerpunch
Oct 25, 2009 02:32 PM
Valafar
Mar 30, 2009 07:49 AM
adanac
May 14, 2008 09:39 PM
gmaltese
May 12, 2007 09:55 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
