Driving and random grinding noise happened
Yep. Does the Sound like its coming from the front passenger hub??? Time to change your transfer case switch. Dorman part# 600-500. Also check the accuator thats under your battery. There are a few great U tube video on Blazer 4x4 accuators.
I agree, transfer case vacuum switch leaking internally, which partially applies the clutch shaft in the RF axle. Under $20 and 15 minutes to replace it. Only the 3 button transfer cases have the vacuum switch. 4 button is done with an electro-vacuum switch on the firewall.
The vacuum switch is ~ 2.5" long, and looks like this:
The vacuum switch is above, and slightly inboard, of the encoder motor, on the driver side. The image below is an NV233 transfer case, (just like yours). The vacuum switch is visible in the image.
Bigredk5
Nov 21, 2015 09:42 AM
Bolbol
Feb 2, 2015 02:55 PM
gjeffries1987
Dec 17, 2014 08:23 AM
lannon_j
Oct 27, 2014 05:36 PM
garynye30
Oct 15, 2010 06:34 AM
