dumb question
dumb question
got a blazer from a friend and was wondering what the two D's (it shows park, reverse, neutral, letter d with a circle around it, and then another d) wonderin if the d with the circle around it is overdrive
RE: dumb question
OD == Over Drive aka 4th gear which is a 0.7:1 gear ratio
D == Drive aka 3rd gear which is a 1:1 gear ratio
2 == 2nd gear which is a 1.75:1 gear ratio
1 == 1st gear which is a 3.06:1 gear ratio
RE: dumb question
which should you drive in
normal conditions
normal conditions
RE: dumb question
Always drive in OD unless you find that the transmission is constantly downshifting and then upshifting in short order.
RE: dumb question
Kyle do you have the gear ratios for the NP233 t-case? Just trying to figure out a final drive ratio in 4lo vs 4hi
