Electric Fan
Im considering putting electric fans on my 2001. I have a dual electric fan off of a Lincoln Continental. If this wont fit I'm not going to do it, haven't measured yet. Thinking about using on front of radiator as a pusher, once again, not sure if it will work. Mainly thinking about this to gain a couple mpg. Partially just because I can.
You still probably wont notice any mpg improvement, but if it is done right you will have better cooling, and wont have to listen to that loud a$$ clutch fan anymore. And I would probably set it up as a puller instead of in push configuration (that's just me though) that way you have room to put a trans cooler and whatever else you want in front of the rad.
Yeah I have intrepid Efans installed and the clutch fan removed and I got exactly 0 mpg gain. Like swells said tho I would set it up as a puller rather than pusher. 1. It will be a far easier install 2. You will leave space in front for other things and 3. If done properly it can look factory
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
Nope. The auto manufacturers do everything they can to improve mileage & performance. If electric fans made a difference, they'd use them. Granted, the clutch fan is noisy, but it's far more efficient and less expensive than electric. That's why the vast majority of RWD vehicles use them.
punx.inc
12-25-2007 12:07 AM
ivannj
02-14-2006 07:10 AM
